e studio55 bad background
  • lightningjeremy
    • Jul 2009
    • 139
    i did a developer change on this machine because it was overtoning pretty bad. after replacement and calibration the copies look 10 times worse than they did before. background is so bad now the image is barely visible. what did i screw up? thanx
  • Travis06
    Tech.
    • 193
    what developer material did you use?
    • lightningjeremy
      • Jul 2009
      • 139
      i used toshiba developer, d6570
      • tinnyjay
        • Oct 2009
        • 663
        Bad developer would cause a dirty background,not an "overtoned" printing.
        I'd suggest to check corona.If the wires are ok,just clean them and clean also the grid,if they are broken you must change them.
        Also try manual density setting it too low and see if there is any diference and tell us.
        "Who loves the roses,must also bear thumbs"
