Toshiba E-studio e35/45
  • darkmaster
    • 50
    [Misc] Toshiba E-studio e35/45
    Hello everybody, who know how to setup 'waste toner full' alert message when the waste toner full?
    Because my M/C nothing to show when the waste toner is full, after then all waste toner will come make the M/C be come dirty M/C.
    So i hate this kind of M/C!!
  • jamesyboy
    toner monkey
    • Jul 2010
    • 188
    Dispose of used toner ( ).
    • The toner bag becomes full of toner.
    x
    The toner recovery auger moves towards the rear of the copier: the toner bag full detection sensor is
    turned ON.
    x
    “Dispose of used toner” is displayed.
    • When the toner bag full detection sensor is turned ON.
    x
    Copying operation is disabled after the sheet which is being copied is discharged in the paper
    receiving tray.
    Solution: Replace the toner bag with a new one. its looks like the used toner sensor mounted on the rear frame is not working or is dislodged from its mounting
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      The machine is suppose to back up the toner auger and send the message to change waste toner bottle. (there is not a sensor on this one like the 350/352 series). However it leaks almost as much as the bottler holds before it trips this. Most of these are 10 years old and I would recommend an upgrade.
      • darkmaster
        • 50
        you mean upgrade new M/C?
        • darkmaster
          • 50
          x
          turned ON.
          x
          x
          receiving tray.
          How to enable the detection sensor?
          • emujo
            • Jun 2009
            • 3009
            Not sure of what you mean by M/C (main charge maybe?). Once again as the above post clearly state...when the bottle becomes full, the auger gets pushed to the rear of the MFP. At this point it flags a sensor located on the rear frame and displays the "dispose of used toner" message. If you are not getting this message when the bottle is full, then you either have a bad sensor, a bad LGC board, or the auger is so bound up (bushings gone) that it can't move to the rear postion and flag the sensor. The MFP is over 10 years old...time to upgrade to something from the 21st century. Emujo
            • serginho_vl
              • Sep 2007
              • 59
              Waste toner container
              You can do what I do: when I replace the toner bottle, I also empty the waste toner container, even if it's not full.
