Failure of Denali 2nd Transfer Roller
  • sergei
    chinaman
    • Jan 2007
    • 20
    3rd and final post for the day.
    TTEC introduced the new type 2nd transfer roller (the one with green marking) not long ago. This roller still fails below its recommended life, around 30%~40%.
    Have any of you guys encounter this matter in field? Any workaround or countermeasure to prevent pre-mature failure?
  • jawir
    • Aug 2007
    • 107
    Hi,
    I have similiar case in here like this, than i tried to change this roller with analog machine type 1560. certainly you have little bit modificate it, than that roller can install on to denali.
    rgds
    • sergei
      chinaman
      • Jan 2007
      • 20
      which roller are you referring to? it's been some time that i had service that model.. say abt 5 - 6 yrs.. can't really recall which roller is similar to that which you mentioned.
      anyway, i received a new batch of rollers a few days ago. noticed that this time the rollers have red marking instead of green. but can't really see any differences with the previous one with green marking.. will try it out..
      • Nazakat
        • 67
        Denali 2nd transfer Roller
        Hello Sorry
        I cant understand which model of Machine you are talking about.Plz tell me the model then i can give you some idea
        Nazakat
        • sergei
          chinaman
          • Jan 2007
          • 20
          Hi, we are refering to Toshiba eStudio 351c/451c.
          Have you encounter such failures of the transfer roller in your region?
          • Nazakat
            • 67
            e studio351c451c
            Hi, yes i have the same problem.But till the time of writing i am unable to manage some other way.It never produces recomended copies and gets damaged very early. if find any solution, please let me know
            • Nazakat
              • 67
              2nd Transfer Roller e studio351c/451c
              Dear All
              I have found one company which provide the same roller with a very good qulity.I have used that roller......Excelent results....Wanna know that company.
              PM me
              • jawir
                • Aug 2007
                • 107
                HI Buddy,
                sorry has made you confused. the mistake is mine. I slip between transfer roller and feed roller. Plz ignore my reply before.
                regards
                • blue4fun
                  • 19
                  how many paper tray cassett ?
                  • BigDog
                    no more dots
                    Toshiba applied a brownish-red mark to the end of the roller shafts to make them different from earlier, unimproved versions. The improvements have been factory applied and the brown dot is no longer being applied. This was the latest news as of the middle of March.
