Toshiba E-Studio 3511 Asking for toner
  • gitana1983
    • Mar 2009
    • 141
    Hello to everybody.....
    Now we have another issue with this model, we have replaced already two machines and now we are in our third one with this same problem... so.... any ideas of what might be causing it will be really appreciated.
    The problem is that the machine asks for black toner, we replace it and still the machine keeps asking for toner again and doesn't work. We have opened the machine completely, cleaned everything but still the same problem is showing..... so please if anybody ahs dealt with this issue before and knows how to solve it, please let me know.
    Thanks in advance,
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    when was the developer replaced last? No developer and the toner sensor keeps adding hoping to fill up and it never does.
    Have you checked the augers that transport the toner to the developer unit? These break and cause this issue.
    Are you using the correct toner? Oem is the best in this beast.
    Is the toner bottle motor turning and the hopper not packed up.
    • ToshibaTech
      • Apr 2007
      • 580
      I'm gonna bet on the auger and I'm gonna bet if you aren't familiar with it you will not have fun fixing it. Seriously though if you have already swapped out two 3511s at the same place (if I am reading this right) ... ? .. Then I would seriously consider putting a DIFFERENT model in there.
      I will not give you service manuals or firmware.
      • gitana1983
        • Mar 2009
        • 141
        Originally posted by toshibatech
        i'm gonna bet on the auger and i'm gonna bet if you aren't familiar with it you will not have fun fixing it. Seriously though if you have already swapped out two 3511s at the same place (if i am reading this right) ... ? .. Then i would seriously consider putting a different model in there.
        thanks for the advises, we are going to try everything.... And then will post what works. The exchanges has been in two different locations, but now we got to the third one... So we need to solve this issue or is going to get bad...
        I'll be posting the results, and once again thanks to all for the advices!!
        • emujo
          • Jun 2009
          • 3009
          You need to put the machine in test mode and run the toner bottle forward and reverse. I have had motors work well one direction, but sluggish the other direction, there is also a 1 way clutch on the hopper assy that can go bad and cause the toner delivery slip when trying to add toner. 4511 is pretty old, I would rip out the hopper, put a new motor and clutch in, and replace the delivery auger. Emujo
          • tinnyjay
            • Oct 2009
            • 655
            Emujo has right,but if the toner motor is working,you must clean the sensor,deep inside the toner hopper.
            "Who loves the roses,must also bear thumbs"
