Toshiba_eStudio2330c: scan/fax sw
  • boran
    • Jul 2025
    Hi,
    I bought a second hand one of these and have setup it up with printer drivers I was able to download.
    Next I'd like to be able to use it as a scanner, and to send faxes, from Windows XP.
    What (simple) software to I need to do that? It doesn't seem to be in the drivers I found at Toshiba?
    I don't want any massive suites that take over my PC either..
    UPDATE: I should note that I found out it publishes an SMB share and there I can see scanned documents.
    Thanks in advance.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Does it have a fax board?? If not then it will not fax. Also the full installer (cd iso option) contains the fax driver. You do have to use the custom install to get it.
