e-STUDIO6520C - OSX 10.6.4 - No Job Accounting Selection
  • Calcucatus
    • Mar 2010
    • 16
    The install "driver" program will not work with this copier and there's no instructions of course. I manually loaded the PPD and features now appear.
    At any rate, I'm looking for the "Job Accounting" pull down. Everything else installed okay, I can select trays and options fine, but no where is there a selection for "Job Accounting" - of course the customer wants that feature. The rest of this office has Windows XP and they work fine with the feature, only the Mac refuses to list this. Turning off Job Accounting on the copier allows this machine to print to it without problem. Any suggestions?
    Thanks,
    CC
  • ToshibaTech
    • Apr 2007
    • 580
    Are you looking under the pull downs with Color 1, Color 2, Paper Handling, etc etc.... It should be under one of those but I can't remember which one. I've used department codes before on Mac with success.
    I will not give you service manuals or firmware.
