Went out to the customer this morning. Rebooted everything, but the copier only prints from a job that appears to be in memory. Even if I create a new document, it spits out a job it's holding in memory. THANKS
e-studio 35 will not print new jobs. Only prints from the hard drive.
Thanks guys. I did as you said and it worked, but there's more to this story. I'm not that familiar with this machine, obviously, so I didn't realize that the copies come out inverted. Well, after reformatting, I was still getting the “job stored in memory” prints. Turns out, the frig’n cheap customer (They are chargeable.) had loaded the paper tray with a previously run job. It was a Homer Simpson moment. Lesson learned. The error light still comes on, but as far as I can tell, everything seams to be working fine. Thanks again.Comment
