The Counter Function
  • kenziebean
    [Misc] The Counter Function
    In my office we have a Toshiba e-studio 3500c. I want to know how to read the counter for a given period of time. As of now, I can only pull up a Total Counter that shows every printed/copied/faxed item to date since we got the copier. How can I make it spit out just results from 9/1/10 - 9/30/10?
  • ToshibaTech
    • Apr 2007
    • 580
    Not possible. Easiest way is to just do the math. Long way around would be to use department codes or you could clear the job logs then export them to CSV, put them in excel and do some calculation with the data. Easiest way is to just do the math I think. (Get meter today, get meter on the next date, subtract.)
    I will not give you service manuals or firmware.
    • ivovb
      • 695
      Set up notification for counter. In this way You will get every month on 25th (for example) e-mail with total counter.
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
