TSB models with USB dongle
  • Scanrom
    • May 2025
    Hello !
    For what Toshiba models I need for print/scan that USH dongle activator ?
    I now that for Es 45 is 1020 .
    Please tell me if is the same situation for Es650 , 251c/351c/451c.
    Bogdan
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    estudio 200l/230/280
    gm-1020 print enabler
    gm-2020 print/scan enabler
    gm-3020 scan update enabler.
    estudio 202l/232/282
    gm-1070 print enabler
    gm-2070 print/scan enabler
    gm-4070 scan update enabler
    estudio 350/450
    gm-1010 print enabler
    gm-2010 print/scan enabler
    gm-3010 scan update enabler
    estudio 352/452
    gm-1060 print enabler
    gm-2060 print/scan enabler
    gm-4060 scan update enabler
    estudio 520/600/720/850
    gm-1050 print enabler
    gm-2040 print/scan enabler
    gm-4010 scan update enabler
    estudio 550/650/810 requires
    ga-1040 or gl1020 to do any scanning.
    all color machines scanning and printing are standard and no dongle needed.
    Also Toshiba released a "1" version (change the last 0 to a 1) on some of these models that required a firmware update to use. I also believe that the machines ending in a 3 (283,203l,453...) required the "1" version to work.
    • Scanrom
      mamy thanks for reply !
      • ripleyha
        Re: TSB models with USB dongle
        Mr. Spock,
        You listed the GM2070 as the print/scan item number for the 202L. Is that correct? I have seen mostly the GM2080 when I have searched. I can't find a GM2080 and they are listed at $700 or more. The GM2070 seems to be available and priced around $200. Please advise.
        Thanks,
        Ripley
        • Gregg
          the GM2070 is for the 232/282
          I have both types of enablers if you need any.
          • ripleyha
            Gregg,
            So am I correct that the 202L needs the GM2080? I have also seen a GM 2081 listed.
            Do you have new or used? What price?
            Thanks,
            Robert
            • Gregg
              Yes, thats for the 202. the gm2081 is for the estudio203L
              Email me at Niceguyfinishing1st@gmail.com and we can discuss what you need and price.
              Gregg
              • Mos
                • Feb 2022
                • 1
                Gregg
                I need to get GM-2060 to enable print/scan on a Toshiba e-studio352 device.
                Is it possible to get the ISO of this GM-2060 and burn it to a usb flash drive?
                  • 8101
                  This is very old, long ago discontinued technology. I doubt you can get an ISO. I am fairly certain you need the physical dongle inserted at all times into the copier for the feature to remain active.
                  This very much predates the license technology used by Toshiba copiers today and is considered obsolete.
                  Nowadays, Toshiba simply prints your license number on your invoice. There is no exchange of physical goods.
