Toshiba E-Studio 3511 showing error CF50.
  • tinnyjay
    • Oct 2009
    • 663
    Hello
    Toshiba E-Studio 3511 is showing error code CF50.
    Changed,sensors,developers,LGC board and still the error is present again.
    I am ready to give up,please help me.
    Bye
    "Who loves the roses,must also bear thumbs"
  • bellsysjoe
    • 12
    call me at 704-562-1543 will help with error code
    • tinnyjay
      • Oct 2009
      • 663
      What is this ?
      A Hot Line ?
      Lol
      • bellsysjoe
        • 12
        I am a tech can help you with any problems
        • tinnyjay
          • Oct 2009
          • 663
          You want to increase your number of posts,only with these kind of posting.
          Foolish
          • bellsysjoe
            • 12
            Just trying to help you If you need the help call if not dont
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              Color auto-toner sensor abnormality: The connection of the color auto-toner sensor cannot be detected at the initialization, or the output value of color auto-toner sensor when the revolver starts rotating for initialization is out of a specified range.
              Check the sensor (under the inner tray) and clean the grey patch with AIR only. Anything else will require replacement of the patch. Then run 05-207 and 05-208.
              • tinnyjay
                • Oct 2009
                • 663
                Sensors are changed 3-4 times,LGC board,developers,wires.
                And i cannot enter 05 mode or 08.
                Not so easy to do.
                Never happened before like this.
                • Mr Spock
                  • Aug 2006
                  • 2064
                  If you cannot enter 05 or 08 mode then I would flash the firmware. If that does not work replace the hard drive. If that does not fix it then it will probably be the system pwb.
                  • tinnyjay
                    • Oct 2009
                    • 663
                    Solved,thank u
                    • digivision
                      • Aug 2009
                      • 44
                      hi dear fnd,
                      i need e 351 c FW, can i have it?
                      I have all other estudio fw & Sm
                      BR,
                      • tinnyjay
                        • Oct 2009
                        • 663
                        Originally posted by digivision
                        hi dear fnd,
                        BR,
                        I dont have firmware for 351c.
                        By the way you have all e-studio firmwares.
                        Can you send e-studio 3511 to me please.
                        I live in Europe
                        tinnyjay@hotmail.com
