Toshiba E-Studio 311c CF1 Error Code.Need help!
  • tinnyjay
    • Oct 2009
    • 663
    Hello
    I have a Toshiba E-Studio 311c and after too much tries i just made it to work.
    First it showed me CE2 error code and after set 08-742 to "0" and 743 to "1",CE2 dissapeared.
    08-742 means "Automatic Color Registration on start up" and i dissabled.
    08-743 means "Manual Color Registration"
    After performing 05-245(Automatic Adjustment of Autotoner Sensor Registration) everything is ok,the voltage is 4.0 V (normal is 3.5-4.5 V),i tried 08-879 (Automatic initialization image quality control) without any possible error.
    I enabled again 08-742-1(Automatic Color Registration on start up) and dissabled 08-743-0(Manual Color Registration).
    Make some tests and the results were not so good.A faulti image(very low quality image, blurred and 4 colors were everywhere even the original wasn't like this).
    I tried 05-407(Forced performing of color registration control)as the Service Handbook says and it showed me CF1 error code.
    After restart,CF1 dissapears,but faulty color images are still there.
    TB,drum,developers,coronas are functional,because they're tested on other machines.
    Sensors are cleaned first and changed after,but still the same.
    Please can somebody helps me what to do,because these are consecuences of somebody else,i must pay.
    Bye
    "Who loves the roses,must also bear thumbs"
