I have a problem with scanning to a file using a GL-1020 on a windows 2003 server domain (win2000 native mode). This worked fine before the upgrade form NT4 domain to Win2003. I understand the GL-1020 cannot digitally sign SMB, so that has been turned off on the domain controllers using GPO.
It is definitely a authentication issue. I took a domain pc and set up a share on it. I created a local user, gave the local user and a domain user access to the share. Using the local user in the scan template, the scan worked fine. Using the domain user, the scan failed each time with a
"Specified \\\\pcname\\scan path is invalid. Check destination path"
error. The user name and password was the only thing changed in the scan template. I have tried several different naming conventions for the domain user includung
username
domain\username
username@dominname (fully qualified as yyy.zzz.org)
In the hopes that may work. No joy.
Suggestions?
username
domain\username
Suggestions?
