E-Studio 3511 cyan toner
  • stevee104
    • Mar 2007
    • 214
    Machine gives a message to replace cyan toner, i have clean the toner sensor, change the cyan dev
    and did dv calibration check all the augers in the toner and dv unit none are broke but can't get the message to go away. The book said the sensor controls all colors so why is picking on the cyan.
    Any input would be real helpfull.
  • ss12
    • Jul 2008
    • 289
    try checking the doctor blade to see if it is at the correct height
    • stevee104
      • Mar 2007
      • 214
      do you know the gap size for this, I have looked in the manual and i cannot find it.
      • ToshibaTech
        • Apr 2007
        • 580
        Check the flags which are actually part of the toner cartridges. If they are messed up or dirty they may cause the problem. If you look at the rear of the toner it's the square "hole" which rotates around underneath the sensor.
        Also and more likely IMO did you clean the correct sensor? There are two of them over the revolver unit. One is the ATDC sensor located over the middle of the revolver. The toner detection sensor is located at the rear of the revolver. They are both mounted on the plate over top of the revolver, accessed by removing the exit/receiving tray.
        I will not give you service manuals or firmware.
        • ss12
          • Jul 2008
          • 289
          not 100% sure but i think it`s 0.55mm.There was a bulletin about this a while ago.you can try increasing the gap slightly and see if this makes any difference
