Toshiba e-studio 163
  • PEPELEMU
    Tech
    • Oct 2008
    • 38
    I have a estudio 163 that is ghosting. Coming from the developer unit. Put in another machine and does same thing. Replaced mag roll same thing. Make multi copies and first page ghosting eventually goes away. Repeat multi and same problem. Any other ideas?
  • tomcatt
    • Jul 2010
    • 92
    Re: Toshiba e-studio 163
    Man I have got the same problem on a e 165 ghosting. Let me know if you ever fixed it. Possibly something with developer .Customer added developer to toner box because the yield was 90k vs 24k.hhmmmm
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • tomcatt
        • Jul 2010
        • 92
        Your response to every fricken question is to order a manual is getting old and annoying. Also your avatar is a little creepy for my taste. Sometimes the answer is not always in the manual. Thank you
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          I would order a new dev unit and see if it fixes the issue. I have had one on the 230 series that had some issue and replacement was the only solution.
          • didi2005
            • May 2011
            • 401
            Whole process unit problem or only developer unit problem?
            Normally ghosting is due to drum side & main charger problem....
            • Toshitec
              MFP Engineer
              • May 2011
              • 22
              You can try to change the bearing on the mag. roller.
              Sometimes it gives to much resistance to create good bias.
              And check the contact-springs in the side-cover for the transferunit.
              Good luck.
              ps. I also get very tired of mr. Manual
              • savi0r
                • Sep 2010
                • 363
                I subscribe to what didi said.
