Anybody have detailed instructions on how to set up Scan to email and scan to file?
Toshiba e Studio 452
Tags: 452, detailed, email, estudio 35, file, instructions, multifunction printers, scan, scan to email, set, studio, toshiba
Check this link for the drivers you need, Office Multifunction Printers (MFPs) - Toshiba e-STUDIO for remote scanning.
Use the e-bridge system to communicate with your computer by Network only.
No remote scan is supported to MAC at the moment.
Also check this site for all your user books as you need, for Toshiba Machines.Comment
Toshiba Operator Manuals and Reference Materials for Scanning complete guides and all original user documentations for all Toshiba Estudio Machines.Comment
Please send me the correct drivers to scan from MAC, Or I never configure the system correctly in MAC.
Any advice will be appreciated. I need to perform Remote scanning for MAC for a Toshiba Estudio 351C.
I found remote scanning software from Toshiba support site.Comment
What drivers are you referring too for scanning, are you Network scanning (push) or twain scanning (pull).
You don't need drivers for Scan to email/folder or the file share on the Toshiba, setup in done thru Top Access.Some days, it's just not worth chewing through the restraintsComment
Yes I can scan in the copier ans share.
I need to scan from the MAC, remote scan.Comment
Mac can also access the SMB share. I don't know the exact procedure but you "connect to a server" in Mac terminology. I think the protocol is something like smb://servername. It was fairly obvious I remember that much after you find the "connect to a server..." in Finder.I will not give you service manuals or firmware.Comment
Thanks.Comment
