Toshiba 452
  • makaule
    • 74
    Toshiba 452
    Can anyone write P/N of harness which connects to Auto Toner sensor in dev unit ?
    Thanks.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • Mad_Coachman
      • 99
      What problem are you having? The reason I'm asking is that I've never seen a harness go bad in these machines.
      • makaule
        • 74
        Forgot to plug connector to sensor after cleaning and changing developer and it seems that I managed to brake the wire when pushing dev unit into copier. "Insert Developer Unit" is on display.
        • Mad_Coachman
          • 99
          Splice,baby,splice
          • makaule
            • 74
            Wire is broken somewhere under the shell. I can't see where it is broken..
            Need only P/N.
            • Brizey
              • Dec 2010
              • 15
              6LE78259000 HRNS-FRT-364
              easy as 1,2,3.
              I WILL NOT BE GIVING OUT ANY FIRMWARE OR MANUALS, 2 MEMBERS TOOK ADVANTAGE OF THIS VALUABLE RESOURCE AND NOW HAVE SPOILT IT FOR THE REST.
