1370 won't feed
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    1370 won't feed
    Hello everyone,
    I have a Toshiba 1370 that won't feed from the paper or bypass trays, the tires don't spin at all. I replaced the whole paper feed assembly (from a parts machine) without success. Anyone know how to use the test mode on this machine. Intravia has something about it their guide but I can't figure out how it's supposed to work. Any advice is greatly appreciated.
    Thanks.
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
  • Travis06
    Tech.
    • 193
    Make sure the drive gear that drops when the clamshell closes, isnt sticking up. I've used to run into that quite a bit.
    • User Name
      Awesome Sauce
      • Nov 2009
      • 405
      Yes, that would appear to be it. I'm in the process of cleaning it up now. Thank you so much. Having this machine running will make my day. You sir, are AWESOME!!!
      O.o
