e-studio 45 light copies
  • serginho_vl
    • Sep 2007
    • 59
    Hello!
    I have a problem with an e-studio 45. It started loosing toner (because the developer is old). I've cleaned the corona units very well, also cleaned the inside of the machine, took the developing unit and the drum unit from another working machine and put them in the first machine. Copies are still light. The drum in the second machine is new (around 500 copies) and the developer is used, but in the second machine the copies are very good (much darker then when I put them in the first machine). I've also made some prints from the computer - same situation - the first machine with the new drum prints lighter then the second machine with the used drum, so I guess it's not the optics.
    Any ideas?
    Thanks for all the help you'll give me!
  • TECNICO5
    Originally posted by serginho_vl
    hello!
    I have a problem with an e-studio 45. It started loosing toner (because the developer is old). I've cleaned the corona units very well, also cleaned the inside of the machine, took the developing unit and the drum unit from another working machine and put them in the first machine. Copies are still light. The drum in the second machine is new (around 500 copies) and the developer is used, but in the second machine the copies are very good (much darker then when i put them in the first machine). I've also made some prints from the computer - same situation - the first machine with the new drum prints lighter then the second machine with the used drum, so i guess it's not the optics.
    Any ideas?
    the problem is the bias,under the developer unit there is a peace of iron..try this
    • serginho_vl
      • Sep 2007
      • 59
      Put back the old developing unit (the one that was spilling toner), and the copies are darker now ... So it seems the other developing unit was to blame for the light copies. I'll put the other one in and adjust the developer bias value.
