Toshiba Estudio 351C
  • jcontractor
    • Aug 2010
    • 247
    Toshiba Estudio 351C Copy Quality
    Originally posted by Mr Spock
    Start by cleaning the machine, and I mean everything. pull the transfer belt out and clean all the rollers under the belt. clean the laser glass, and check the drum,drum blade, and main charge.
    Just for feedback, I perform all the copytechnet forum expert advice and the machine goes better and better. I clean all the laser system, it goes better. The customer approve the copy quality but with a compromise witch consist in change TBU unit kit.
    Here is an item that I never expect a few days ago, The machine gave a Call for service or Maintenance required condition. When I hit my customer office and turn the machine on the machine didn't gave any message, but I check the 08-251 (Counter on 120,000) and 08-252 (counter in 101,000). I just reset both counters and then the copy quality goes 100% of it's performance. Incredible; I do bias reset on small printers like Brother and It goes better in copy quality, but those are small monochrome machines. I never expect the same in this big machine.
    Well, it is produced by reset the bias in the machine?
    Voltages goes to default conditions?
    At the time the machine is printing 100% in black and 100% in color mode.
    It just print incredible clear, sharp, vivid, etc.
    I will appreciate any comment about this.
    • jcontractor
      • Aug 2010
      • 247
      Originally posted by ameritech
      Hello jcontractor, I was working on a 281c, similiar machine, I change the belt and drum, but it had the same problem, so I change the transfer roller that is in the transfer belt unit, and that fix the problem.
      • jcontractor
        • Aug 2010
        • 247
        Originally posted by jcontractor
        Thanks, also I clean the Laser unit and It's printing better.
        • jayc67
          Independent technician
          • Sep 2009
          • 100
          #19
          Hello!
          I'm looking for parts for Toshiba e-studio 351C. Can anybody help me?
          • tinnyjay
            • Oct 2009
            • 663
            #20
            Mr Spock,please really i need your help.
            Would you be pleased to check my post here :
            http://www.copytechnet.com/forums/to...-firmware.html
            Please help me
            "Who loves the roses,must also bear thumbs"
            • michaelc
              Field Tech
              • Mar 2011
              • 590
              #21
              People have already asked if you have cleaned certain parts. Clean the laser slit glass (atleast), the charger and grid, inside the transfer belt unit and the whole machine. When these machines are clean they work well. You said the machine had 87000 copies. How many are colour and how moany are black? The drum x4 when doing colour for instance.
              The 3511 blade will not fit a 281c tr unit.
              It didn't say that I couldn't do it in the manual.
