This 2500-c has only two drawers and I am getting skewed copies from both drawers and bypass. I have swapped out all the transport guides and sensors,the entire door with the transfer roller, transfer belt unit and more I cant remember right now. Have any of you other techs ran into a skewing prob on this model? I would appreciate any suggestions. Thanks
Toshiba 2500-c skewing copies
Check the 2 white (they are white on the 3500c) registration roller holders. My guess is one will be flipped up in to the wrong position. It can easily be done if you have had the transfer belt out without even noticing, done it myself.I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
