When trying to do a staple job, it will give the message, "CHECK STAPLER"
Pull cart out, remove a few from the front, reload cart, it will not try to feed staples.
But there is no message for loading staples like it was empty of staples.
Tried swapping out the staple unit itself, checked connections at the finisher PWB.
Could not find a mode to test function of the stapler unit.
May try the PWB next, any ideas though.
