E-282 LVPS
  • mhmsaqer
    field Supervisor
    • Jun 2007
    • 83
    E-282 LVPS
    hi guys
    is there any known issues with this power supply(E-282 LVPS),as so far i have more than five machines down for the same reason.
    the machine boots until the main screen then it goes off & the main switch returns back.
    is there any thing we can do with failed board.
    regards
    Be happy for a moment - this moment is your life.
    Omar Khayyam
  • tech-wazza
    • Dec 2007
    • 7
    Try checking the fuser lamps. If they are short circuited they can cause the machine to automatically shutdown for protection. Also try resetting the 08-400 fuser error counter as well.
    • mhmsaqer
      field Supervisor
      • Jun 2007
      • 83
      Dear all,
      I've all of my boards repaired at some local electronic workshop,but as you know they will not told us what was wrong with those boards.
      the heaters have nothing wrong and they just work fine when you replace the LVPS.
      some thing might be configured with those boards ,just like the E-35 LVPS
      Omar Khayyam
      • silni
        • Sep 2007
        • 10
        Look for triacs attached to large heat sink. Those are your problem.
        • jawir
          • Aug 2007
          • 107
          Hi,
          Have you tried to fix the Power supply? try check the TRC for fuser lamp in the power supply.because e282 has 2 fuser lamp, the TRC must be two too in there. ussually one of them broken. i think you can find this TRC in your local market.
          thanks
