Toshiba e-studio 2330c suddenly OFFLINE
  • Zhaak001
    How do I fix this problem? Was working fine yesterday, and today when I wanted to print it says the printer is offline
  • Meach
    • Nov 2008
    • 128
    If the 2330c network setup was set to DHCP the IP address may have changed when the copier was turned on. Check the IP address in your printer setup on your PC and see if it is the same as the copier.
    • emujo
      • Jun 2009
      • 3009
      You may also want to restart the print spooler service.Emujo
      • ivovb
        • 695
        Check printer driver in XP if set to offline. Right click with the mouse and set to online.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • thejack
          • Jan 2011
          • 35
          check the printer setting
          1 check ip address its working(ping)?
          2 set ip address on static.
          3 check printer option(online... offline.)?
          (Right click printer driver icon)
          4 check priner spooler services ?
          5 reconnect or reinstall the printer driver?
          Best Regards,
