- I open the machine
- machine's door open and close
- I've installed the software again
- but it still does not work
Toshiba 166 Scanner
It means that cover of the original is open - no front door, no side cover. It might be sensor or software version issue. Anyway which Toshiba viewer version did You install?
BRI'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads. -
Thank you to everyone
Do not touch the sensor cover.
Press your feet on the cover, the problem is solved.
Thanks DigivisionComment
