Error setting toner density
  • Claudio_
    Hello.
    I have e-studio 550/650 and I want to decrease its toner density in printing and copying (print and copy more lightly)
    When I press in startup [0+8-414-4] for 0.8% lower toner, the toner density in printing is the same, does not change.
    Is this the wright configuration for doing that?
    Thank you in advance.
  • tech-wazza
    • Dec 2007
    • 7
    After changing this setting you will need to run a number of test copies through the machine in order for the developer to adjust to the new setting.
    • Claudio
      • Feb 2007
      • 235
      See your Service Handbook 05-501 through 05-515 ( The higher the value the darker the density ),
      05-593 through 05-595 ( The higher the value the darker the density ).
