Toshiba Studio 3500 CS40
  • pukiro
    • Feb 2011
    • 59
    [Error Code] Toshiba Studio 3500 CS40
    Hi guys
    please help me!, i am working on this machine studio 3500 and i have the code cs40, any idea on what is it...
    as im a ricoh engineer and dont really work on toshiba machines
    thanks
  • Meach
    • Nov 2008
    • 128
    Im looking at the manual for the EStudio 3500c. I dont see that code listed. Are you sure it is a CS40 not CB40 or CA40 or C140 or C940 or CC40 or CE40 ?
    • pukiro
      • Feb 2011
      • 59
      hi meach
      i will check the code again...
      thanks for your reply.
      • ToshibaTech
        • Apr 2007
        • 580
        If it is CE40 you probably have a depleted developer. Take all the imaging units apart, clean the charges and inspect them one by one.
        I will not give you service manuals or firmware.
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          CB40???
          Does it have the booklet finisher installed? If so check the saddle stitch push plate mechanism and clock flags and sensors.
          I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
