e-Studio 45
  • Doctor
    • Sep 2010
    • 133
    e-Studio 45
    My estudio 45 doesn't print. Even the test print from the copiers control panel does not print. Days later it may just print. I am thinking of formatting the hdd but don't know the code. Is it the same for estudio 282? Ihave manuals for 282 but not for 28.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Which controller? it could be the hard drive in the controller and that will need special firmware to reload it.
    • Doctor
      • Sep 2010
      • 133
      I think its a fiery controller. I did 08-690-2 and there is no difference.
      • Mr Spock
        • Aug 2006
        • 2064
        No fiery on this model. It had an embedded controller (under the scanner on the left side of the machine) and a gl1010 Big bump on the left rear of the machine. Has a cd rom on this one. Both require special firmware to reload and a special app for the embedded to do this.
        • emujo
          • Jun 2009
          • 3009
          If it is the GL1010, try this...open Top Access (IP address of the controller) Log in as admin, find the "logs" page and start deleting all of them. Scan, Print. Error, and message (i think). Each time you send a job, the controller rebuilds the logs. When you have 1000s of messages that have never been deleted it takes a long time to do this and the print process slows down considerably. If this does not help, and it it a GL 1010 you should think about replacing the HDD and updating the controller OS to the latest and greatset version which will help. Original HDD was around 40gig, but you can put up to a 140GB drive (I believe). New software will be 1 CD to format/partition the drive for the new Linux OS, and the 2nd CD will load the new OS. PM me if you want the CDs and instructions to do this. Emujo
          • Doctor
            • Sep 2010
            • 133
            Then it should be the embedded controller cos there is no bump on the rear. Pls can you help me with the firmware and the special app.. I started with Toshiba on e163, 282. This e45 is old and dont have the manuals and firmware. Thanks
            • jinxs
              • Feb 2010
              • 43
              next thing i would like to ask is, is your computer's OS.
              this model does not support windows 7, btw
