I am proposing a solution to a Hospital Print shop that involves creating Saddle stitch booklets using EFI Seequence software suite "Impose/ Compose" software on a current #GA1131 Fiery 8e controller from a e3530c Colour copier.
I want to export that file as a Flattened PDF to two e755 cpm Black only Non Fiery copiers with Saddle stitch Finishers operating in tandem via Toshiba Job Point software. Do you think it will work?
I believe the file will print as a PDF OK.
My concern is things like pull tab paper from drawer 3 will not work.
I believe by definition a "flattened PDF" will โfuseโ active elements of the file like annotations and form fields into a single element of the PDF that can no longer be edited or manipulated.
