Toshiba eStudio 351c latest Firmware
  • Azharm
    • Aug 2025
    Does anyone know where I can find Toshiba estudio 351c latest fireware. Also how i can update the firmware on my estudio 351c. Any hep would be appreciated.
    Version Information
    Printer Manufacture TOSHIBA
    Copier Firmware Version T410SY0U050
    Copier Main ROM Version 410M-04
    Copier Scanner ROM Version 410S-04
    Thanks.
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Version 050 is a older version of firmware. I use v350 at the moment. You might have to use the jigs to manually update the firmware via the system board before updating the firmware to the latest version. Is there a reason for the need to update the firmware?
    I cant give out firmware.
    A toshiba engineer should be able to update the machine and would carry the latest firmware with him.
    It didn't say that I couldn't do it in the manual.
    • Azharm
      Thanks for reply, actually this old ver 050 don't have SSL encription option to enable in SMTP Clint setup, have only plain or login encription options. Actually we are using google apps and google email required SSL encription enable to use as a SMTP clint
      My setting as follow but is won't work. Actually i want to use scan to email, scan to file is working fine with no problem.
      SMTP Client
      Enable SMTP Client: Enable
      SMTP Server Address: smtp.gmail.com
      POP Before SMTP Disable
      Authentication: Plain or login ( i tryed both won't work)
      Login Name: outbound@domain.com
      Maximum Email / InternetFax Size: 20 MB
      Port Number: 587
      SMTP Client Connection Timeout(1-180): 30 Seconds
      DNS Session
      Enable DNS: Enable
      Primary DNS Server Address: 8.8.8.8
      Secondary DNS Server Address: 8.8.4.4
