What do I need to add for a estudio 35 to print and scan?
E-35 print/scan
Gregg
Stick with print if you can, the scan was a P.O.S. and support will be limited.
I have a print controller if need one, no scan though.Comment
The GA-1040 wont support anything past WinXP 32bit only. The GL1010 if updated to the latest firmware will support up through Vista (I think) and will allow SMB, FTP, and Email scanning. I personally belive you are better off looking for someone that needs a boat anchor, not a print solution for this Toshibasaurus. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
Re: E-35 print/scan
E-studio 35 supports 2 print controllers:
- ga1040 - print only
- gl1010 - print & scan (for scan you need version 2.x system software, for version 1.x scan was optional)
Maybe you can find a used one.
On Toshiba | Managed Print Experts | Multifunction Printers and Copiers, Color Copiers, B&W Copiers, Faxes, Scanners | Toshiba Copiers you'll find the drivers for both (vista drivers usually run on win7 too).
GA1040 Drivers v1.3
GL1010 v2.30 CD Drivers- zip - + GA1040 Windows XP/2003 PCL6 v1.3 Certified 07/08/04 - zip - + GA1040 Windows XP/2003 PSL v1.3 Certified 07/08/04 - zip - + GA1040 Windows Vista PCL6 (not-certified) 11/19/08 2.95.213.0 - zip - + GA1040 Windows Vista PS (not-certified) 11/19/08 2.95.213.0
