Toshiba 451c Firmware Error
  • Idris0009
    • Jun 2025
    Hi All,
    So I was updating the firmware on a new HDD I attached to a e-studio 451c and I got a message stating the hard drive failed to update(HDD SYS Update: Failed). Any thought on what I'm doing wrong? All other updates passed installation.
    Cheers,
    Idris0009
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Is it 160gb HD? Sometimes you need to set the hard drive to master or CS (cable select). You also need to partition the hard drive before installing the firmware. Hope that helps
    It didn't say that I couldn't do it in the manual.
    • Idris0009
      Sorry for the waste of time. USER ERROR. :S I didn't run the 3&0 option 3 command. Once I did tat it ran fine. Thanks for your reply. Have a great day.
      • hoanphuc20033
        • Mar 2011
        • 38
        hello
        c+3 to format hdd
        if hdd finshed is ok
        check hdd
        MOVING SERVICE COMPANY LTD Emerald Buddha
        Address: 202 Tran Hung Dao Q1 TP HCM VIỆT NAM
        Expert: sales, leasing, salamanders provide copier parts warehouse.
        Tour: board repair resource, sys board, main board, board scan ...
        Expert: purchase, exchange, used copiers.
        Tel: (08) 54041727 - 0938877144-0976583422 Mr. NGHIỆP
        YM: tienphatngoc2011@yahoo.com / hoanphuc20033@yahoo.com
        GM: vannghiep25@gmail.com
        Westie: mayphotocopytienphatngoc.blogspot.com
