1370 cq repeat image
  • lac14903
    • Jun 2007
    • 5
    I have A 1370 THAT HAS DECIDED TO TRACK THE IMAGE. It looks like eather drum ground or erase lamp. Lamp is working, machine is clean I can adjust some of it out with exposure but not all of it. been in the busness for 20+ years with Savin and Mita Need help with this thing
  • wagon
    Village Idiot
    • Dec 2006
    • 654
    Is 'track the image' what I would call 'offsetting' or 'image repeat'?? Maybe the drum blade? Could the fuser roller be stuffed? From what I remember 1370's were OK little machines (its been a while!). Maybe the drum is worn out and oversensitive?
    If you are hitting your head up against a wall it always feels better when you stop.
    • imaginGuru
      Don't forget
      Also don't forget to clean and isolate the separator corona blocks+change wires, it's very common at this point of its life for this part to leak HV and cause lotta trouble, (faint image, repeated image, blank copies, intermitent jams...etc).
      imaginGuru
      • Boogotshot
        • 61
        Check your drum blade to see if it is flipped. Those little things were notorious for flipping the drum blade if you didn't use enough patting powder.
        sigpic No! we never do that with the copier.
