Toshiba 281C error Code CE90
+ More Options
Posts
  • gitana1983
    • Mar 2009
    • 141
    Hey everybody... happy belated easter to all
    Have Toshiba 281C with error code CE90. I know is related with the drum thermistor but everything seems to be working fine, all connections are fine,etc.
    Any idea on what else I should look or any reset?
    Thanks in advance for any help
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      When people remove the process unit on those machines they sometimes forget to unplug the drum thermistor. I have had to replace the drum thermistor wire harness in the past due to this. Have you checked the to make sure the thermistor is working? Connector 333 (CN333) on the logic board and pins A10/A11.
      It didn't say that I couldn't do it in the manual.
