drum change instructions...
  • copymane454
    [Misc] drum change instructions...
    on a toshiba e520......how do i get that drum out of the machine....i got the toner box out.....easy enough..but now it is wayyyyyyyyyyy out of my league.....someone help....this account has four of our machines...and this came off lease with another company....so i can use a hand with this....thanks
  • JustManuals
    • Jan 2006
    • 9838
    Paul@justmanuals.com
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      Start with the cover over the toner unit (2xscrews)
      Above toner unit is 1xscrew which drops a stopper out.
      Disconnect toner connector.
      On the bottom of toner unit, pull the pin downward until it stops.
      Swing toner bottle to right angle of machine and remove.
      Remove next cover (3xscrew)
      Remove toner hopper (2xscrew 1xconnector)
      Developer lever in the down position, 1xconnector, removed developer unit.
      1xconnecto, 1xscrew, remove charge corona unit.
      2xscrew on drum unit frame (marked with arrows) removed drum nit.
      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
