ES-600 F110
  • oscar
    • May 2010
    • 45
    ES-600 F110
    My ES-600 when I turn is giving the code F110 need help.
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      It is a communication error between the scan logic and system boards. Easiest thing to do first would try and upgrade the firmware. Check to see if the machine updates the firmware.
      It didn't say that I couldn't do it in the manual.
      • oscar
        • May 2010
        • 45
        where I can get the firmware of the equipment?
        • JustManuals
          • Jan 2006
          • 9838
          I have the firmware. It's not free though.
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            I do not give out firmware or manuals. I do not know how much manuals4you will charge.
            If you update the firmware and the scan firmware fails, could be the scan logic board. If the firmware will not install at all it could be the system board.
            Make sure the usb/pen drive you use will work on the machine when updating the firmware. There is a procedure to follow when updating the firmware also, which I can help walk you through.
