Another Estudio 3500c finisher question
  • copierdan500
    • Apr 2011
    • 26
    When changing from a MJ1030 to the 1101 finisher, is there anything to do other than changing the 0-8 service mode, 1912 from "0" to "1" ?
    Because we have had several of these machines that code out a 570 when we try to do this. They will only work with the big folder finisher....We updated the firmware but no change.
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    The small finisher interface board that mounts on the system board is different for a MJ-1101, you need to replace that when changing the finisher.
    Some days, it's just not worth chewing through the restraints
    • copierdan500
      • Apr 2011
      • 26
      Ah-ha! thanks
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        if you flash the ipc (finisher interface pwb) to 1.4 then it supports both.
        • copierdan500
          • Apr 2011
          • 26
          Can you tell me the process to do this?
