Put down the dip switches at the left upper side to get in 05 mode with hold them down and then switch one the machine. if AJ is displayed push start the carrige move there is a poti inside dev unit upper side left (opening the front cover same at first this one you have to friggle find oth the center of exp. led......that is i remember
