e2500c MAG ROLLERS
  • arnh79
    • 468
    e2500c MAG ROLLERS
    Has anyone tried using the new style knurled mag rollers from the e2830c series devs on a 2500c series machine? We have a lot of problems with the mag rollers crapping out on us and wondered if this might be a solution. Tosh says they're different part numbers and are not compatible, but they seem to have identical dimensions. As long as the gap is set correctly I figure we'd be ok.
    Any feedback would be appreciated!
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    I have never tried it, but I would like to know how it goes. Maybe just try a black unit first? It may not be the dimensions it could be to do with the toner and developer?
    It didn't say that I couldn't do it in the manual.
    • arnh79
      • 468
      We've got a machine in shop I can use to test. Will let you know how it goes.
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        thanks, we dont have many out there now so i cant have a go myself.
        • dogg_man
          • Jun 2011
          • 48
          We have done a 4520 mag roller update on the 2500C developer units. Just set the doctor blade height to the specs for the 4520. It's not a "approved" mod, but works like a champ!
          • jltwitch
            • Jul 2010
            • 29
            We have done this on a few machines that were pulling Dev in the 2500 series, they seem to work fine now.
            • arnh79
              • 468
              Thanks for the feedback guys! I'll order in a few of the e4520c series rollers and give it a try.
              • djbass
                • May 2008
                • 167
                Re: e2500c MAG ROLLERS
                Would also be interested to know how well this works as I've contemplated it myself.
                Official word is that 2500c roller should be completely smooth and 4520c rollers should be rough due to both units using a different developer mix.
                In the field where I've seen techs mistakingly rough up a 2500c roller it has resulted in premature wearing of the drum.
                No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
