e150 "E7-11" help
  • CCS
    • 266
    e150 "E7-11" help
    I have this one e150 in the field that keeps intermittently coming up with "E7-11", turn off/on and goes away sometime for days, or sometime just for a few copies.
    I have done general cleaning of optics and such, code keeps coming back.
    Manual says something about CCD white level trouble, what does that mean actually ?
    Also says "dirt on shading plate" for E7-11, what exactly should I clean ???
    I have several of these machines in the field, never this problem, please help
  • ivovb
    • 695
    It is a Sharp actually and the options are:
    CCD drive circuit (CCD PWB, ASIC harness) trouble
    Copy lamp lighting trouble (Copy lamp, inverter PWB)
    You have a good start but pay attention of a white stripe when cleaning original glass inside. Also You can try stick another white stripe using white adhesive tape. Unfortunately these wouldn't help always and You will have to change some of the previously mentioned parts.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • Travis06
      Tech.
      • 193
      Maker sure you pull that lense/mirror unit apart and clean the inside mirrors. Are you getting light copies when it works.
      • CCS
        • 266
        Thankyou
