reboot machine
  • piculito
    • Aug 2025
    [Error Code] reboot machine
    i have a e-studio 2500c toshiba and it continues to say reboot machine. i reboot but it comes back again after a while. need some sudgestions ty
  • arnh79
    • 468
    If there's no error code in the history to help you then I've often seen the wrong driver create that message. We had a customer who's IT guy had loaded an old Tosh driver for a different machine and everytime they hit print they'd get "reboot copier".
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • piculito
      Ty I'll check driver
      • ivovb
        • 695
        One more thing. If OS is Win7 You have to update to latest firmware/driver. Win7 with old firmware/driver can cause reboot the machine indication.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • fourl6
          • Nov 2008
          • 94
          its defiantly computer related, iv had a es2820c saying reboot machine like a call for service but with no code, only happen when a certain laptop was connected to their network.
          it could be either wrong driver or and copier/printer monitor software installed on a pc
          • dogg_man
            • Jun 2011
            • 48
            Reboot Machine messages usually indicate the copiers HDD is going bad. Replace the HDD and firmware associated with it.
            • remielee
              Technical Analyst
              • Mar 2010
              • 140
              Re: reboot machine
              try to run the hdd reset, off the machine press/hold 08 then pres 690 then pres start button the default value is 2 then press enter, when the copier indicate to reboot the machine turn off then wait for 10 second to on the machine again. hope it helps.
              • emujo
                • Jun 2009
                • 3009
                Re: reboot machine
                Possibly, but as posted above, w/o any "F" codes in error history, HDD replacement would probably be waste of time. BTW, I've only had 1 of these SATA drives fail in the 3510C series over the years, and that was partly a result of power (sags) problems. With the older IDE drives, I'd tend to agree with you a little more. Driver issue is more likely the culprit..Toshiba likes to match drivers with firmware updates...some over eager IT rep has probably spotted a newer version of drivers and installed them w/o the necessay update to the MFP firmware 1st. Emujo
