e2330c with Fax Kit
  • didi2005
    • May 2011
    • 401
    [Misc] e2330c with Fax Kit
    Received fax will print out using A3 paper... (Intermittent)
    But when i check back the print logs, incoming fax is printed as A4-R....
    MFP drawer 1 = A4, drawer 2 = A3.
    Is it A4 drawer busy, it go to A3.... or sender's paper size is longer than A4, thus print out as A3?
    I tried to change the attribute paper type to "FAX" for drawer 1...But later all A4 print job will go the bypass tray...
    Any idea?
  • ivovb
    • 695
    Did You try to have paper source with A4-R? If not applicable check 13-517.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • didi2005
      • May 2011
      • 401
      I've enable 13-517. Customer insist of using A4 and A3 size on drawers. I've also enable the reduction features on Top Access--> Setup --> Fax.
      I've tried send fax using paper size longer than A4 using DP80F, when receiving fax, MFP detect as B4 paper, and print out using A3 paper...
      When i send fax using paper size A4 paper, MFP detect as A4-R paper and print out using A4 paper...
      Is the regular reduction B4--> A4 not working? or bcoz customer has A3 paper?
