ES203SD OC float issue
  • jltwitch
    • Jul 2010
    • 29
    Hey all, im setting up a new ES203SD and putting on the MR2019 Doc feeder and got the first part done where you set test mode 26 to 2 so the RADF is on, but when i do the OC float mode 41-06 I get an error everytime and when I try and run a copy thru the doc feeder it will go thru but is blank, copies are fine from the class. any thoughts?? thanks much.
  • jltwitch
    • Jul 2010
    • 29
    NM I overlooked a step, didnt do the 53-08
