toshiba eStudio 2020c
  • aligis
    • Jul 2010
    • 56
    hi Gurus,,, well yesterday toshiba 2020c control panel was not working it takes commands, but in panel it remains Warming up,,, and network init.... and nothing after that after a long time...
    even when you go into diagnostic mode of 0-8, 0-5 it take comands but remain tilt with WAIT nothing
    i tried out
    updating frim 3.3
    deleting partitions +firm but did't work out formating hd with 08-690 because as i mention above WAIT
    Chaing hard drive nothing same problem...
    any clue
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: toshiba eStudio 2020c
    What about the RAM on the system board. I sometimes have gotten away with cleaning the contacts with a clean rubber (before anyone else commentS, I mean eraser). Or you could change the ram to be sure. If not maybe try the system board itself.
    It didn't say that I couldn't do it in the manual.
    • aligis
      • Jul 2010
      • 56
      well we have change da hdd , formatting with 08*690 , nothing .. then changing the sys board its ok but when i disconect fax it worked.. thought it was fax caed but i was wrong, installing new one..... same thing now have to work with nvram....
      another problem is that the printing is very slow and not even open topacess even i have enabled it in the admin manue.
      neeed help
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        Was it a new hard drive? You clan clear the ram flags using clear+3 and option 1. Can you get into the 05 and 09 codes now?
        • aligis
          • Jul 2010
          • 56
          i have tried now we have send the board in guarantee,,, it was nvram and sys board...
          actualy connectoing fax it went in tilt ... so what u say
