c970
  • poco
    • Sep 2007
    • 7
    c970
    toshiba 350 repeated C 970 code tried cleaning contacts and replacing transfer assy still get calls intermit any ideas help!!!!!!!!
  • ss12
    • Jul 2008
    • 289
    C970 is a main charge leak problem.try removing a loop from the charge wire spring or putting a damper on the charge wire.Also would'nt hurt to check the end blocks
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Re: c970
      Just to add to what ss12 has said. I also take the charger cleaning rods out to. No customers use them
      It didn't say that I couldn't do it in the manual.
      • JustManuals
        • Jan 2006
        • 9838
        Re: c970
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • tech07
          • Aug 2008
          • 410
          Re: c970
          the key to most 970 codes is the vibration of the main chrge wire. The newest wire springs are heavier and pull the wire tighter. I've had really good success with them. I have also cut a couple loops off the original spring with good success as well.
          • toshibadale
            • Apr 2007
            • 117
            Re: c970
            C970 can also be T/S corona wires. We starting stringing our own with Katun wire, and have not had a problem since.
            • WOETC
              Re: c970
              AS stated C970 can be Transfer /Sep corona or Main Charge, must say I've never noticed one with vibrating wires, though I can quite believe it. In my experience the most common issue after the old foreign object in the corona assembly trick, or broken component is arcing of the corona end blocks. I keep clear nail varnish in my tool bag, pull the whole unit apart and varnish the end blocks where they come into contact with the tray. Lasts for years, if necessary.
              • JVC
                • Jun 2011
                • 151
                Re: c970
                The calls for 970 code have gone way done since I started stringing the wires. It took some practice but it is worth it. I have also used white out on the end blocks.
                • didi2005
                  • May 2011
                  • 401
                  Re: c970
                  I do encounter C970 due to main charger wire dirty... After cleaned, it can work nicely... But i found that some machine the wire get dirty easily... even after changed whole main charger unit, it will happen again...
