Toshiba EStudio 282 "Close Front Door"
  • EricPogi
    • Aug 2025
    [Misc] Toshiba EStudio 282 "Close Front Door"
    Toshiba Estudio 282 machine keeps saying "close front door" however all doors are closed. I've checked already the front door switch and it seems working properly. Any other reasons for this indication in the display? tnx, eric
  • JustManuals
    • Jan 2006
    • 9838
    Re: Toshiba EStudio 282 "Close Front Door"
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • Gregg
      Look for a hole in the front when the doors open where a microswitch should be right under a label that has the S/N and model. Usually gets pushed in.
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        You will need the little micro switch also activates or you wont get your 5v like gregg said.
        It didn't say that I couldn't do it in the manual.
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          Also check the fuses on the power supply. If one of these is blown that is the message.
          • hassan123
            • Nov 2009
            • 19
            CLOSE FRONT COVER
            Mostly the problem of power supply.
            check the power supply.
            • EricPogi
              Tnx Sir's for the advice, I've got it working yesterday. The problem was on the power outlet, i test the voltage and it gives me 110v only. My bad i haven't check it first from the start. Again tnx!
