e studio 230 hard drive format
  • yannii33
    • 121
    How do I format this hard drive and do I need some software to load in itThanks
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: e studio 230 hard drive format
    Depending on the issue you are faced with, you may not have to format it at all. What makes think the HDD needs reformatting?
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • yannii33
      • 121
      On the screen its showing different format options
      • jonezy999
        just one copy??
        • Feb 2010
        • 952
        Can you wxplain a bit clearer? I don't understand what you mean.
        • yannii33
          • 121
          Basically the customer installed a hard drive it needs setup and formating I just wanna know if I can do it from the machine or is there third party software I need to use to setup the hardrive
          • arnh79
            • 467
            You need to partition the HDD and install factory firmware.
            Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
            • michaelc
              Field Tech
              • Mar 2011
              • 590
              arnh79 and jonezy have gave you the info you need, I just am wondering why and how the customer changed the hard drive.
              It didn't say that I couldn't do it in the manual.
