Need Parts manual for toshiba e stu 3511
  • koslonny
    Getting error code cebo. think i have to order some parts.
  • lkrsardis
    • Dec 2007
    • 316
    toshiba part list
    ftp.collinsdistributing.com they have the parts list on this site. It is to large for me to email.
    Like the United States Postal Service It's a miracle it works!
    • silni
      • Sep 2007
      • 10
      CEB0
      Black developer unit lifting movement abnormality
      Is the black developer lifting clutch working properly? (Perform the output check: 03-433)
      NO 1. Check if the connector of the black developer lifting clutch is disconnected.
      2. Check if the connector CN362 on the LGC board is disconnected.
      3. Check if the connector pins are disconnected or the wires of harnesses are open
      circuited.
      4. Check if the conductor pattern on the LGC board is short circuited or open
      circuited.
      5. Replace the black developer lifting clutch.
      6. Replace the LGC board.
      YES
      Are the black developer contact position detection sensor and black developer contact timing
      detection sensor working properly? (Perform the input check: 03-[FAX]ON/[1]/[C], /[1]/[B]
      NO 1. Check if the connectors of the black developer contact position detection sensor
      or black developer contact timing detection sensor are disconnected.
      2. Check if the connector CN361 on the LGC board is disconnected.
      circuited.
      circuited.
      5. Replace the black developer contact position detection sensor and black developer
      contact timing detection sensor.
      YES
      1. Check if the conductor pattern on the LGC board is short circuited or open circuited.
      2. Replace the LG
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        If it has not been done I would start with the front cam update part number is 6la48643000.
