Estudio 45 erasing scanned copies
  • wnteja
    • Jul 2011
    • 23
    [Misc] Estudio 45 erasing scanned copies
    How are you.
    I have a Client machine estudio 45 it erases all the scanned documents soon after scan task is finished. I deleted all the files in the hdd but still the problem persists. Any idea to be the cause of this?
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: Estudio 45 erasing scanned copies
    Scan to efiling or scan to file?
    It didn't say that I couldn't do it in the manual.
    • wnteja
      • Jul 2011
      • 23
      Estudio 45 does not have efiling capability. The problem is scan to file. Even if you scan more docs before getting done it erases all the pages.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Does it have the gl controller on the back left or just the Ga print board?
        If it is the GL which version o/s. With the early versions you need a scan dongle. With the latest you do not. Without the scan dongle it will scan and then delete like you stated.
        • wnteja
          • Jul 2011
          • 23
          It only got the Ga Printer board. When scanning docs for multiple copies after pressing the finished button so set copies to be produced it erases all instead.
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            You can save to the machines hard drive on this machine. Was the 1st machine with this on. It was not called efiling though.
