Removal of Output trays/Finisher 351c
  • dasbrow
    • Jul 2025
    How hard would it be to move a finisher from one 351c to another? Would I need to worry about settings in the firmware on the unit that the items are being removed from?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Removal of Output trays/Finisher 351c
    Remove finisher, bridge unit and ipc pwb from logic. Install on other machine. Make sure machines are off before removing or installing. Also you may want to swap covers for safety reasons (if the one that is receiving has never had a finisher before).
    • dasbrow
      Thanks Spock. Does the new unit need to have any initialization done? Maybe those instructions are in the service manual, which I have.
      • Mr Spock
        • Aug 2006
        • 2064
        Only if going to or from the mj-1101. Otherwise they are plug and pray!
        • dasbrow
          Sorry for the revive of this older thread....
          I have removed the finisher from one unit and have moved it to another and it is not showing up, anyone know what else needs to be done in order for the unit to see the out put trays/stapler?
          Thanks!
          • ss12
            • Jul 2008
            • 289
            Remove the ipc board on the main board(the little piggyback board rear of the machine top right).fit this onto the other machine,you should be good to go
            • dasbrow
              Crap figured I forgot something. Will go grab it.
              Thanks!
              • dasbrow
                I went yesterday to grab the IPC unit and there is nothing on the main pcb board. I never checked to see if the finisher even worked on that unit before I removed it. Attached is a snap of the pcb. there were some pins in the top right that the pictures does not show, but nothing was connected.snap_pcb.jpg
                  • 8193
                  Try 08-1912-1 to initialize the Finisher.
                  • dasbrow
                    Thanks, tried and it didn't do anything.
                      I went yesterday to grab the IPC unit and there is nothing on the main pcb board. I never checked to see if the finisher even worked on that unit before I removed it. Attached is a snap of the pcb. there were some pins in the top right that the pictures does not show, but nothing was connected.[ATTACH=CONFIG]12372[/ATTACH]
                      Looking at the machine from the back as photo the ipc board is on the board to the right of this one
