How to enable External Key counter in Toshiba eStudio355
  • ramdv
    • Aug 2025
    Hello,
    I have a Toshiba eStudio355 copier. I connected External Key counter harness on the board. Is there any procedure that i should configure so as to enable this feature on the copier ? If so, How should enable it ?
    Thanks in advance,
    Ramesh
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: How to enable External Key counter in Toshiba eStudio355
    08 - 202 set to 1 for coin controller.
    It didn't say that I couldn't do it in the manual.
    • ramdv
      Thanks very much !!
      I have a question. Is this going to stop the un authorized users from copying at the printer ? Correct me if iam wrong.
      My idea is...i want to setup external key counter so that the users should not access it. Only authenticated users should get the access to copy. Please help me in this regard.
      Many Thanks,
      Ramesh
      • sdrawkcab
        Confused & Bewildered
        • Jun 2009
        • 317
        Just use the Department Codes function
        Some days, it's just not worth chewing through the restraints
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          I didnt read the first post properly, If you are using swipe cards for people to use the machines then it depends. I am not sure on the print side. I have a customer who needs cards t copy but prints do not as each person logs on to the network which the printer is on. Since I messed up I will give you the code relating to it and hopefully some one with more knowledge can help you more. Also as sdrawkcab said, department codes could work to.
          08+202
